How do I remove my front pipe?
Old Jun 23, 2020 | 09:49 AM
Tajohns34's Avatar
Default How do I remove my front pipe?
Hey guys and gals. I have a couple of rust holes in the front pipe on my 2000 blazer 4x4 4 door. I cut out the rusted piece and patched in a new one and welded about 3/4 of it. Does anyone know a good way to remove the front pipe completely so I can get a good weld around the whole thing? Do I need to remove the trans cross member? Thanks folks.
Old Jun 23, 2020 | 11:04 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
To get the front pipe down you need to remove the trans support. I had to use the torch on each and every one of the bolts to get them loose up top at the manifolds. IIRC those are 15mm.
Old Jun 23, 2020 | 04:02 PM
Tajohns34's Avatar
Thanks. The manifold bolts are brand new and so are the manifolds. The bolts rusted and I thought that was my leak. Turns out it was a rust hole in my exhaust.
Rivaltitan
Oct 10, 2019 05:23 AM
Dkarll88
Mar 17, 2019 10:15 PM
Alexis_the_s10
Jan 16, 2018 05:45 AM
Brian_D
Apr 1, 2012 10:48 AM
johnnyblaze
Sep 24, 2006 11:32 PM
