How do I replace the drivers side mirror?
Old Feb 28, 2009 | 07:45 AM
danzy55's Avatar
danzy55 is an unknown quantity at this point
Default How do I replace the drivers side mirror?
Greetings all,
I have a 97 Blazer and the drivers side mirror just broke off, on the backside their are three plastic points where it bolts to the door, all three plastic connections have busted off.
I've ordered a replacement but do not know how to access and attach the new mirror. Can anyone offer some advice?
thanks
Shane
Old Feb 28, 2009 | 10:38 AM
Default RE: How do I replace the drivers side mirror?
You have to remove the inside door panel. There are a few screws and then the push clips. I would get a proper trim puller as they are cheap enough and make it easier. If you search in the A/V section, you should find a link to a how-to on replacing the front door speakers which runs through the removal of the door panel.
Old Feb 28, 2009 | 12:36 PM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
After you get the door panel off remove the power mirror harness/clip and there should be 2 or 3 rubber pieces covering the holes there are nuts behind them. I believe they are 10mm
Radio
Feb 7, 2018 03:29 AM
scphill34
Mar 10, 2013 03:59 PM
Wexinlo
Apr 6, 2011 11:35 PM
pghblazer
Dec 19, 2009 02:30 PM
gmaltese
Oct 19, 2006 11:30 AM
