How do I reset passkey system 01 ZR2 Blzr?
Old Oct 27, 2009 | 05:28 AM
avionicsncoic's Avatar
avionicsncoic is on a distinguished road
Default How do I reset passkey system 01 ZR2 Blzr?
Vehicle starts, then dies after 2 seconds, "security" light on steady. I had just replaced a bad alternator which of course required battery disconnect. Any ideas appreciated as I do not want to pay a tow-bill and a FAT dealer maint bill for what ought to be a quick procedure. Thanks.
Old Oct 27, 2009 | 06:28 AM
THIS POST should help. I have to redo the Tech Article.
Old Oct 27, 2009 | 07:56 AM
Thanks I'll give it a try!
Old Oct 27, 2009 | 09:54 AM
Followed procedure - didn't work. I note though, that the "SECURITY" lite is on steady vice flashing as called out in procedure. Any ideas?
Ok - followed another procedure I found through Google which basically said to attempt start, leave key in run position for 10 min then reattempt start from run position (don't turn to OFF). That didn't work either, so,
I disconnected battery for a couple min, reconnected, SECURITY lite now flashing vice steady, and joila - vehicle started first attempt, runs like a champ. Go figger, lol! Thanks for the reply though...
Old Oct 27, 2009 | 11:30 AM
If you cannot get the security light to blink like it is supposed to, the PCM has locked out the possibility of a self relearn. As you have found out, resetting the PCM often can unlock the passlock system and allow for a self relearn. If a battery disconnect does not allow for a self relearn, then you only other option is to get it force relearned by the dealer.
Bmxxxtonyg
Jul 29, 2022 06:12 PM
WBFAir
Sep 22, 2014 08:00 AM
dr_ahmad
Oct 8, 2012 01:44 PM
kulls61
Mar 1, 2008 06:43 PM
WyteNyte
Feb 16, 2006 05:32 PM
