How to remove rust in cylinder
Head cracked on my 95 4.3 and had heads removed and reworked. It took awhile and now surface rust is in the back 2 cylinders.
What would be the best way to remove it without scoring the cylinder walls?
Liquid rust remover has not removed it all. It is pretty heavy right at the top where the piston and cylinder meet.
Thanks in advance for any suggestions.
I wouldn't worry too much about a little surface rust...it will clean itself. You can take a clean rag with a little engine oil on it an wipe off most of it. You should, however, check your cylinders for wear with an inside caliper. It doesn't look like you planned a rebuild but it's something you might as well check whiile the heads are off.
do you have all the pistons out? then just do a quick honing job and the will be cleaned up nicely
as to leaving the rust in that can cause premature wear on the rings
Or if you don't have the pistons out you can pour some marvel mystery oil in there....or PB blaster....or even WD-40..... once you have the rust out you could smear a little lithium or bearing grease (use very little) on the walls to keep it from rusting again untill reassembly.
I 2nd marvel mystery oil if the engine is assembled I have used this to free up rings that rusted to the cylinder walls in salvage motors and would not turn over.
If you are rebuilding I would use a ball hone.
make sure you dont get that stuff on your shoes or you wont be able to stop
Just saying to make sure your safe
Chic_Bowdrie
03-31-2012 08:47 AM
mbar
11-10-2010 02:39 PM
