How to replace weather stripping? (2002, 4wd, 2-door)
Old Jun 23, 2018 | 12:11 PM
RedValor's Avatar
RedValor is on a distinguished road
Default How to replace weather stripping? (2002, 4wd, 2-door)
When I bought my Blazer used from another guy, it had a weather stripping issue with wind noise, so I bought 1/2 inch standard weather stripping from Home Depot to stick around the door. That worked out for a while, but now rain water is leaking in, so I bought new weather stripping from LMC Truck to install and do the job right. I'm a little stuck on how to remove the plastic paneling around the inside. From the how-to videos I was able to find there should be screws holding the floor paneling in place, but my vehicle doesn't have them. Should I just pry with a screw driver and hope for the best?
EDIT:
Being careful, I was able to pry with the screw driver enough to discover the paneling is held down by metal clips, so I was able to get it off that way can get the weather stripping installed. The other pieces of weather stripping, that I wasn't able to get from LMC Truck, on my vehicle that's old and tearing way I still have questions about.
Also other bits about my weather stripping that should be looked at:
There is a piece on the driver side along the middle window that's been tearing for a while now. I didn't see a replacement part for this on LMC Truck, so how would I go about fixing/replacing this?
There is also a piece on the driver side on the windshield near the top that doesn't seem to have a tight seal anymore. How would I patch this, or should I?
And finally, there's another plastic strip on the driver door that runs along the top to the hinges that has been broken since I bought the vehicle. I didn't see a replacement part for this on LMC Truck either, so how would I replace it?
Old Dec 30, 2018 | 11:34 AM
whitedavidp's Avatar
whitedavidp is on a distinguished road
Hi. I am suffering the problem shown in your 2nd photo on my 1995 2.2L, 2-door. Looking around, I found this page. Seems like what I need is marked #4. Anyone have any info on how to remove/install? Thanks and happy new year!
Old Jan 3, 2019 | 02:33 PM
In looking I found this and it looks like the weather stripping is part of the glass assembly (now discontinued of course).
whitedavidp
Jan 3, 2019 02:39 PM
mattjphoto
May 8, 2013 11:02 PM
Sisk
Jan 20, 2011 01:08 PM
bamahunter
Jul 2, 2010 11:59 AM
CheapBeer
May 26, 2010 08:11 PM
