How to rotate lines on fuel spider?
Old Mar 28, 2012 | 08:20 PM
Red 96's Avatar
Red 96 is an unknown quantity at this point
Default How to rotate lines on fuel spider?
OK, yet another question....the instruction sheet that came with the fuel spider says that
all lines should be rotated to point away from the fuel pressure regulator end.
It came with them all pointing toward the regulator.
I have tried to turn them the other way but they won't budge, and I'm afraid of breaking something.
Is there a method or trick that I'm overlooking?
Old Mar 28, 2012 | 11:28 PM
onebadsuv's Avatar
onebadsuv is on a distinguished road
are safety screws in place holding clips to secure the injector lines ? If so , just loosen the screws a turn or so and move the o'ring sealed fuel lines into the desired position and re-tighten the screws .
Old Mar 29, 2012 | 03:01 AM
Red 96's Avatar
Thanks for the reply.
Yeah, I already loosened the screws and tried turning the lines, but they're still not wanting to give.
I wasn't sure how to approach it, and I am afraid of breaking them, so I thought I needed to ask here.
They need to be rotated nearly a full 180 degrees, and man they're stuck in their present position.
When I get back out there later today I'll have another go at it, and I'll post back here what I find.
Thanks again.
hunter05
35
May 16, 2024 09:01 PM
wyattt
Jan 11, 2015 09:53 AM
blazerMIA
Oct 3, 2014 12:17 PM
hunter05
Mar 29, 2014 11:32 AM
Big Eazy
Apr 27, 2013 12:48 PM
