How wide is a 1998 Blazer 4x4 rear axle without ZR2 ?
Old Sep 7, 2020 | 10:51 AM
jetmac's Avatar
jetmac is on a distinguished road
Default How wide is a 1998 Blazer 4x4 rear axle without ZR2 ?
I think a junkyard sold me an incorrect axle. They sold it to me as a 1998 Chevy Blazer 4x4 without ZR2 but it is about 2" shorter than the axle in my 1999 GMC Jimmy 4x4. Measuring from inside, hub mounting plate to hub mounting plate it's about 49" but my Jimmy is about 51".
How wide should a 1998 Blazer 4x4 rear axle be?
Old Sep 7, 2020 | 11:10 AM
LannyL81's Avatar
Is your Jimmy a 2 or 4 door?
I will measure the one in my '02 4 door, 4wd.
I will measure from side to side, below the diff.
Measured between the backing plates and right at 51"
Sounds like they may have sold you a RWD axle.
Old Sep 7, 2020 | 12:45 PM
jetmac's Avatar
Thanks for the info. Mine is a 4 door
Old Sep 7, 2020 | 05:13 PM
jetmac's Avatar
Is this a Blazer you measured or a Jimmy? I was hoping someone
would have a measurement for a similar 4x4 Blazer, 2nd Gen, preferably 1998 or 1999
Old Sep 7, 2020 | 06:42 PM
check my build thread. Itll be close to the end of it. I have the measurements of both 4x4 and zr2, front disc to disc.
99 blazer 4 door
Old Sep 8, 2020 | 08:01 PM
LesMyer's Avatar
2wd 54.5"
4wd 59"
ZR2 63"
Rear end widths are measured from wheel mounting flange on axle to wheel mounting flange on axle (not backing plate). Yours should be 59"
Old Sep 10, 2020 | 03:05 AM
jetmac's Avatar
Thumbs up
Originally Posted by LesMyer
2wd 54.5"
4wd 59"
ZR2 63"
Thank You. Very helpful.
Old Sep 11, 2020 | 10:20 AM
puttster's Avatar
Lanny, pls check PMs
Old Sep 12, 2020 | 08:26 AM
LannyL81's Avatar
puttster....no PMs..???
Old Sep 16, 2020 | 08:45 AM
puttster's Avatar
rats. try again?
Diane Elliott
Feb 21, 2020 12:04 PM
Dallas1970
Feb 22, 2019 05:05 PM
outback
Dec 22, 2010 06:38 AM
robbiegamble
Feb 14, 2009 12:20 PM
