I have a 2000 blazer Lt 4×4 with 4.3 Vortecit needs outer axle bearings
Old Oct 28, 2018 | 10:12 PM
Travis Lee's Avatar
Travis Lee is on a distinguished road
Default I have a 2000 blazer Lt 4×4 with 4.3 Vortecit needs outer axle bearings
Can someone tell me whit size axle bearings it needs any help will be appreciated thank you
Old Oct 29, 2018 | 12:03 AM
GeorgeLG's Avatar
I just did my 2WD rears on a 2002. I can tell you that most parts selectors were wrong and the best fit came from pulling the bearings, measuring them and then ordering the replacements.
George
Old Oct 29, 2018 | 12:07 PM
Travis Lee's Avatar
Thank you for the help george a do appreciate it
Old Oct 29, 2018 | 02:11 PM
jparker7269's Avatar
jparker7269 is on a distinguished road
Do look closely at your axles before buying bearings. Sometimes the worn bearing will wear a groove on the axle, you should be able to see and feel it. If so they make a repair bearing that moves the wear surface to a different location on the axle, so you dont have to replace the axle too. I installed one of these on my drivers side and works great. I bought this repair bearing and a replacement bearing on the other side from Autozone. The take your seal with you as there are two different ones made for them.
Old Oct 29, 2018 | 02:20 PM
Travis Lee's Avatar
Yeah I'm pretty sure that the bearings were a Groove in the axle shaft I bought the Blazer a few weeks ago and it was making the sound I have no clue how long they drove it like that thanks i didn't about the repair bearing that you mentioned. Thanks for the input i do appreciate it
Old Oct 29, 2018 | 04:39 PM
GeorgeLG's Avatar
If you are going to try the repair bearing route look for a high quality choice. I have read more reports of failure than success and because of that I opted for new axles as well. If you go the repair bearing route please report your results.
George
Old Oct 29, 2018 | 04:53 PM
Travis Lee's Avatar
If i do go repair route i will let reports the result
Old Oct 29, 2018 | 09:31 PM
odat's Avatar
You can also get a speedy sleeve that presses on the axle to repair the damage but all in all your best bet for repair is a new axle, The race of your old bearing should have a set of numbers on it that will aid in bearing choice.
Old Oct 29, 2018 | 10:07 PM
Travis Lee's Avatar
GeorgeLG
20
Jul 27, 2018 02:58 PM
chevy77
Aug 3, 2017 08:28 AM
lazyboyjake
Oct 2, 2014 05:02 PM
walleyehunter
Jul 26, 2013 11:00 PM
willy4820
Feb 10, 2011 11:27 AM
