bearing question
Old Jun 12, 2017 | 03:49 PM
chevy77's Avatar
chevy77 is on a distinguished road
Default bearing question
is there a definitive way to test the front passenger axle bearing without taking everything apart
Old Jun 13, 2017 | 01:10 PM
chevy77's Avatar
nothing
Old Jun 13, 2017 | 06:18 PM
newguy's Avatar
if your talking hub, jack it up off the ground, grab it at 12 and 6 oclock. rock it back and forth. look underneath for axle to move up and down. Not ball joints, axle. If axle moves up and down, hub is bad
Old Jun 14, 2017 | 08:57 AM
chevy77's Avatar
no im talking axle bearing i have a lot of in and out play on the passenger cv axle and when i make a hard right i get 1 loud "pop" there is a very small leak (not even enough to top off between oil changes) if i move the cv in and out by hand i can see a single drop of gear oil drip out
basically i need to know if i can get away with replacing just the seal and axle because i dont have anything to pull or replace the bearing with and my local auto stores dont rent anything to pull a axle bearing
Old Jun 14, 2017 | 10:30 AM
newguy's Avatar
you asked this before already
Old Jun 14, 2017 | 10:45 AM
chevy77's Avatar
ya but i didnt get any answers ive been searching here and google for a couple weeks and there seems be no information about this anywhere kinda frustrating
Old Jun 15, 2017 | 03:51 PM
Rusty Nuts's Avatar
The dripping axle seal isn't going to stop, no matter what the label on the bottle promises. Since the C V shaft has to come out to replace the seal, test it by rotating it in your hands while bending the joint full flex. You should be able to feel it if it's causing the popping noise.
Old Aug 3, 2017 | 08:28 AM
jimspahr@msn.com's Avatar
It would be helpful to post your SUV year, 4WD or 2WD, 4 door or 2 door, stock or modified, no. of miles and so on. Getting an accurate answer for your problem depends on providing good info.
If you don't want to provide that info each post, just put it in the signature so it will appear every time you post. It also helps on some issues to have where you are: winter salt, hot desert summers, extreme cold, also can affect the answer. You don't have to give a street or city. You can just say Upstate NY, Arizona , or New Jersey shore.
brianp
Jun 1, 2020 10:30 AM
Biohazed
Oct 13, 2009 09:21 PM
mikeymo67
Jul 15, 2008 10:20 PM
yazan84
Mar 10, 2008 06:53 PM
yazan84
Nov 13, 2007 12:38 AM
