I have a growl
Old Nov 28, 2015 | 05:55 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Default I have a growl
sounds like behind RPM gauge. Its just started now that I have all the check engine lights off and im back on road. 97 LS 4 wheel drive. It growls until I put blazer in gear and it almost stalls then rpm jumps back up to 7 hundred rpm and so does growl. If it not 1 thing its another LOL
enough info?????
I just do an upper intake gasket set. sealed well around the spider. if this helps????
Maybe fuel lines are vibrating on body?????? But whats that got to do with the drop in rpm?????
Last edited by swartlkk; Nov 28, 2015 at 07:35 PM. Reason: Merging 4 consecutive Posts - Please use the edit feature to add more information if another member has yet to reply.
Old Nov 28, 2015 | 07:36 PM
*Moving to 2nd Gen Tech*
Check to see if your throttle cable is resting against your PCV vacuum line.
Old Nov 28, 2015 | 08:24 PM
Pull the PCV valve out of the rocker arm cover, engine at idle, put a piece of paper over the PCV valve, (vacuum will hold it to the valve). See if the noise is gone.
Old Nov 29, 2015 | 11:45 AM
Red Sled's Avatar
BINGO! Thank you Guys!!!!! You guys ROCK and so does this forum!!!!
Old Dec 1, 2015 | 09:24 PM
WalkGood's Avatar
WalkGood is on a distinguished road
What exactly was the fix?
Old Dec 2, 2015 | 05:27 AM
Red Sled's Avatar
The PVC vacuum line were laying on the throttle cables. I rerouted them.
88s10Blazer
Dec 8, 2024 03:31 PM
ESKYMOPACK
Feb 1, 2012 10:10 AM
RobM
Apr 9, 2011 05:52 PM
whiteman_01
Jul 14, 2010 10:28 AM
neurotox
Jan 16, 2010 09:07 PM
