I should not be able to..
Old Mar 18, 2014 | 12:04 PM
donald_archer's Avatar
donald_archer is on a distinguished road
Default I should not be able to..
remove the key from the ignition when a) the truck is running(in the on position) and b) the truck is in drive?
If the answer is no..then I think I may have a lead in my battery dying problem.
Any thoughts
Don
Old Mar 18, 2014 | 12:07 PM
burned's Avatar
burned is on a distinguished road
I had that issue when I had an 84 S10. They key and tumbler were so worn I could remove the key while its running. That is why its a good idea to have spare keys and not to hang a pound of other keys off the keychain.
Old Mar 18, 2014 | 12:12 PM
jpimp's Avatar
jpimp is on a distinguished road
yea...the ignition tumbler is on it's way out...new ones are cheap and not to bad to replace...if you leave it long enough it will leave you stranded and not start
Old Mar 18, 2014 | 12:33 PM
Default thats what I thought
I have intermittently had a problem where the battery light would stay on and the door chimes would still chime(when the engine off and key removed). It has not done it for a while now but I am suspecting now that the ignition switch is the cause of all or most of my problems
Thank you all..You rock
Don
SubbinBlazer
May 24, 2013 07:42 AM
trobbins
Jan 9, 2013 10:17 AM
ahawks47
Jan 6, 2010 01:12 PM
Dhurteau
Jan 11, 2008 05:31 PM
