ignition coil replacement
Old Feb 19, 2008 | 04:16 AM
skoot61's Avatar
skoot61 is an unknown quantity at this point
Default ignition coil replacement
97 Blazer 6 cyl. I assume the ignition coil module is original and seems to be pinned or riveted onto the mounting bracket. Is there any other way besidesgrinding to get them off? Thanks! skoot61
Old Feb 19, 2008 | 06:42 AM
Default RE: ignition coil replacement
Unbolt the bracket and remove. Then yes, grind off or drill out the rivets. The new coil will come with bolts and nuts.
Old Feb 19, 2008 | 11:20 AM
skoot61's Avatar
Yes, The new one does have small brackets, bolts and nuts... Why would GMattach it in a way that makes a simple thing difficult and annoyingis beyond me... Im going to use a burring bit and drill them off in place... Thanks for your intrest swartlkk.
blainenbecky
Mar 9, 2013 10:38 PM
stevie59
Nov 11, 2011 10:19 AM
gohan69
Engine & Internal
18
Mar 22, 2011 08:12 AM
Lancealot
Feb 22, 2011 07:34 AM
xdieselx3032
Engine & Internal
Aug 14, 2007 10:59 PM
