Ignition Switch
Old Nov 11, 2019 | 08:15 PM
Mods's Avatar
Default Ignition Switch
Just a thought Would a 1999 S10 Trailblazer fall under the GM ignition recall that occured many years back? While the previous owner of mine never noticed any issues before i go and get all the parts i need to get it running i want to know if thats another thing to add to the list.
Old Nov 11, 2019 | 09:18 PM
odat's Avatar
If your switch is bad its on you - if the recall was years ago its dead .. GM only covers a recall for a certain length of time then drops it.
Been there done that .....
Old Nov 11, 2019 | 10:26 PM
Mods's Avatar
I only just got the vehicle recently. So no, not on me.
Im not asking if its covered im asking if it would have been under it and has a bad switch and if i should replace it.
Old Nov 13, 2019 | 03:30 PM
odat's Avatar
Well OK then - If the recall you are inquiring about is the one about the key tumblers being weak and with a wad of keys hanging and having the vibration shutting the switch off it does not look like your affected - and to get technical this recall is for the key tumblers not the ignition switch as it sits lower on the steering column and is two separate units .....
Old Nov 17, 2019 | 11:37 AM
jimspahr@msn.com's Avatar
Mods, I have heard that you can take your VIN to any Chevy dealer and they can check to see if there is a 'recall' on it.
Old Nov 18, 2019 | 12:38 AM
Mods's Avatar
I managed to forget that GM has a specific website for this, when its not 49 degrees out and actually daylight i'll go retrieve the VIN and run it through.
hbs20
Oct 17, 2015 03:02 PM
tony991
Apr 17, 2013 07:13 PM
socal nick
Mar 7, 2012 05:14 AM
JRT
May 24, 2011 05:38 PM
EdenA
Mar 25, 2008 08:04 PM
