Ignition switch removal 1997~ Help
Old May 8, 2010 | 08:40 PM
austinlee's Avatar
austinlee is on a distinguished road
Default Ignition switch removal 1997~ Help
I need help getting the ignition switch removed. I have the reverse torex bolts loose and the top cover is only being held on by the key switch. I can not get the key switch out?
Old May 8, 2010 | 10:53 PM
R134A's Avatar
R134A is on a distinguished road
I do not know why you are removing your ignition switch but if the key still works you need to put the key in the run position and there should be a pin that you push in and ignition switch should slide out. If it is damaged and key will not work you need to drill out the pin to remove it.
duckland23
Aug 3, 2012 09:36 AM
fireman11368
Aug 26, 2011 11:18 AM
bigcheese
Mar 21, 2011 10:32 PM
Sass_e
Nov 5, 2009 10:12 AM
Sass_e
Nov 1, 2009 03:00 PM
