Im going NUTS help me out
Capt Hook
I didnt see your post yesterday
I think this is the line Im looking for when I pulled the intake off I remember this line pulling and popping off, I didnt think about it until after I replaced everything. Ill try and find the transfer case switch. Thanks Ill get back Sunday night.
The lines are messed up. There should only be one check valve. The source line from the PCV fitting goes to the black side of the check valve. The check valve should have two white outlets. One outlet goes to the reservoir in the fender. The other outlet goes to a Tee. One side of the Tee goes to the transfer case vacuum switch, the other side goes to the hard plastic HVAC vacuum line.
er0ck273
07-31-2015 04:10 PM
thereverendbill
05-28-2010 07:26 PM
