Im going NUTS help me out
Old Oct 26, 2013 | 07:46 AM
Hunter66's Avatar
Hunter66 is on a distinguished road
Capt Hook
I didnt see your post yesterday
Originally Posted by Captain Hook
On 4WD there is an additional vacuum Tee with a line that runs down to the vacuum switch on the transfer case.
I think this is the line Im looking for when I pulled the intake off I remember this line pulling and popping off, I didnt think about it until after I replaced everything. Ill try and find the transfer case switch. Thanks Ill get back Sunday night.
Old Oct 28, 2013 | 02:54 PM
Hunter66's Avatar
Here is a vid
of the problem
Old Oct 29, 2013 | 05:14 PM
Hunter66's Avatar
I am still lost, as to where the hose gets connected.
Old Oct 31, 2013 | 07:53 PM
The lines are messed up. There should only be one check valve. The source line from the PCV fitting goes to the black side of the check valve. The check valve should have two white outlets. One outlet goes to the reservoir in the fender. The other outlet goes to a Tee. One side of the Tee goes to the transfer case vacuum switch, the other side goes to the hard plastic HVAC vacuum line.
er0ck273
Jul 31, 2015 04:10 PM
thereverendbill
May 28, 2010 07:26 PM
Puffie40
22
Feb 9, 2009 04:49 PM
JoPre
Tires and Wheels
18
Apr 29, 2008 02:08 PM
pike87
Feb 1, 2008 03:03 PM
