info please re:95 blazer rear wiper repair
Old Mar 3, 2010 | 09:40 AM
JIM MACGILLIVRAY's Avatar
JIM MACGILLIVRAY is on a distinguished road
Question info please re:95 blazer rear wiper repair
Greetings to all,I HAVE A 95 BLAZER THAT I,AM RESTORING ,WOULD APPRECIATE ANY INFO ON REPAIR TO THE WIPER "REAR HATCH" WHEN I TURN IT ON,IT MAKES A NOISE,I ASSUME IT HAS SLIPPED OFF A CONNECTOR ROD OR MECHANCIAL COG,AT ANY RATE WOULD LIKE TO REPAIR AND ANY HELP APPRECIATED,THANKS JIM
Old Mar 3, 2010 | 10:58 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
The 'New Member' section is only for introducing yourself and your truck, not for asking technical questions.
Old Mar 4, 2010 | 01:47 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Not likely. Sounds like the Large plastic gear may be stripped. Usually what happens with these Wiper assemblies is water works it's way down the Wiper Arm Shaft and rusts a metal gear assembly and then the motor wont turn at all...no noise.
If you are hearing teh motor run but no wiping, you may have other gremlins inside the assembly.
Send me your e-mail address and I will send you a Pic of what the assembly looks like when it's opened up. maybe that will help.
cleburne red
Jun 5, 2016 12:51 AM
Helter80
Jun 14, 2013 08:34 PM
behler014
Dec 20, 2012 01:03 PM
bluereign
Oct 13, 2011 09:27 PM
jmberman
Dec 29, 2009 06:18 AM
