infomation center problem
Old May 9, 2007 | 06:35 PM
gserve's Avatar
gserve is an unknown quantity at this point
Default infomation center problem
2000 Blazer LT 4 wheel drive.Has the information center(compass and shows outside temp and fuel economy etc)There seems to be a problem with the temp sensor. Does anyone know where the temp sensor is located and if it is an easy repair? Any advise on this problem please.
Old May 9, 2007 | 08:17 PM
Default RE: infomation center problem
Temp sensor is behind the grill on the hood latch support (center of the radiator).
Old May 9, 2007 | 08:29 PM
gserve's Avatar
Is it easy to replace?
Old May 9, 2007 | 09:43 PM
Yeah. You have to pull off the grill (snaps in - don't forget to unplug your turn signals) and it'll be right in the middle on the hood latch support bracket.
If you unplug it, I believe it should go to something like -20 or something really low. If it doesn't, then you may have a wiring fault.
Here's the location of the two sensors:
ibyz
Apr 26, 2025 10:11 AM
matthewp
Apr 4, 2021 09:16 PM
victorf
Apr 11, 2008 01:12 PM
booblinker
Oct 6, 2006 01:42 AM
Blasir
Sep 6, 2006 08:11 PM
