Inside Dash Rattle...What Could It Be?
Old Oct 12, 2012 | 10:02 AM
LannyL81's Avatar
Default Inside Dash Rattle...What Could It Be?
'02 4dr 4wd: something is making a noise inside the dash that I have not been able to find. Can really only hear it when the right front wheel goes over a series of bumps...like a washboard road at speeds less than 25mph....any faster and not able to hear it.
I have removed the glove box, taken the dash trim panel off, all the lower trim panels, removed the radio, 4x4 switch, headlight switch, temp controls, ash tray, dash speakers, defrost vent (broke it), and rotated the dash forward but did not remove it.
I have removed the temp door motor and checked the movement of the temp door...both were fine. I have checked operation of the inside/outside vacuum actuator, and the blend door actuator...both hold vacuum and the actuator bodies themselves are not moving.
The noise sounds like something inside the air duct, and sound like the noise you get when a house or refridigator, etc AC compressor is shaken....when you hear the internal piston hitting the steel exterior case.
ANYONE have a suggestion as to what this could be?? ANY suggestions at all????
Thanks
Old Oct 12, 2012 | 10:33 AM
spittybays
Guest
Posts: n/a
I have heard this described before and one of the answers are related to the hood hinge cone washer search around. I grabbed this when I saw it for when I needed it.
http://i11.photobucket.com/albums/a1...ge_tsb_img.gif
Old Oct 12, 2012 | 12:05 PM
Rottidog's Avatar
X2 Just reading the header I thought of the hinge washers.
Take a small rag & fold it a few times. Place it on the weather stripping under the hood on the side the rattle is. Close the hood & go for a drive.
If the rattle is gone - voila, you've found the source!
Old Oct 12, 2012 | 05:20 PM
step66's Avatar
X3-However I have noticed this on incomplete dash hardware replacement after a heater core change,all those tiny screws are in there for a reason! Too bad they over engineered the dash but made so many other crucial design fails! I still like my Jimmy,but I am getting tired of it for just this reason!
Old Oct 13, 2012 | 10:49 AM
LannyL81's Avatar
I removed the trim piece at the windshield base....thought they were screws....tried for over 5 minutes to unscrew the thing before I took a better look and noticed it was a plastic retainer.....
Anyways, the passenger side hinge bolt was only finger tight. The drivers side was very tight....but there is no washer on either side and local Chevy stealership shows no washer either.
I just removed the hood and am going to go for a drive down a washboard road and listen.
I was thinking of putting a nylon washer between the hood and the body.
I will edit this with what I hear.
I HEAR NOTHING......YOU GUYS ROCK!!!!
That was the source of the noise. There was not enough space to put the nylon washer in, so I just tightened up both sides and went for several drives...and no noise...it is GONE!
Thank you guys....
Old Oct 14, 2012 | 06:15 AM
LannyL81's Avatar
Edited posting above and again THANKS for the info....SOLVED.
meatbag
Sep 24, 2012 10:26 PM
98Ltblazer
Apr 5, 2011 01:13 PM
xXJump4JesusXx
Jun 29, 2010 08:10 PM
Denominator
Apr 26, 2010 04:15 PM
rastoma
Nov 8, 2009 12:53 AM
