Intake gasket change on 00 4.3
Old Apr 20, 2011 | 07:29 AM
logan_001's Avatar
logan_001 is an unknown quantity at this point
My biggest problem was the ac bracket. All bolts were out and i had to use a prybar to get enough clearance.
Old Apr 20, 2011 | 06:39 PM
blazerblack's Avatar
blazerblack is on a distinguished road
Good luck with the intake. As for the AC bracket, after loosening the 3 bolts you can use a pry bar against the block to bend it a little bit. If that doesn't work (it didn't work so well on mine) then you can use a ratchet strap to pull on the bracket and keep it out of the way to set the intake.
Old Apr 21, 2011 | 04:54 PM
jerseydave's Avatar
jerseydave is on a distinguished road
Note to self........ large prybar....
thanks
Old Apr 21, 2011 | 06:18 PM
Unless you want to do the job again in the near future, use a Felpro gasket set MS98002T. It's a new and improved design, it's a little pricey but WELL worth it. If installed properly and the lower intake bolt threads are cleaned, oiled, sealed, and torqued in sequence to the proper torque, it will not leak.
Old May 4, 2011 | 04:31 PM
jerseydave's Avatar
Had computer issues so I was not able to update until now.
Repair went well, I would highly recommend Dtips to anyone doing this job.
Step by step perfect.
Thanks for the help folks.
jd
Old May 5, 2011 | 08:53 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Rebuilt my 4.3 last summer, intake manifold bolts are very torque critical. torqe it to the specs and pattern, friend of mine master tech at GM dealer gave me a good hint. Torque once let sit for a hour then torque again, use a good torque wrench.
Have fun.
limited edition 1
Jan 27, 2023 11:07 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
