Intake Gasket tools
Old Nov 7, 2008 | 10:47 AM
rmv42158's Avatar
rmv42158 is an unknown quantity at this point
Default Intake Gasket tools
Ok so I have been reading posts and I'm going to do my lower intake gasket this sunday. The problem is I can't seem to locate a torque wrench with inch pounds and a fan belt tool. Is there anythingI can use in replacement of these tools? Any special things I should know? It's ashame i just had the upper intake off to do my FPR and now i find this leak. Figures. thansk for anyput.
Old Nov 7, 2008 | 11:36 AM
WolfPack's Avatar
Default RE: Intake Gasket tools
Fan belt tool? You dont need any special tool to get the belt off...just push the tensioner to the drivers side and take the load off the belt.
If you need the tool to get the fan clutch off, then you can try using a long box end wrench. Put the wrench on one of the pulley bolts (theres 4), and position it so that when the pulley tries to turn, the other pulley bolt hits the wrench. Then hold that wrench still (and the attached pulley), and using a large cresent wrench on the fan clutch shaft and pull apart..its probably on there pretty tight...so keep trying
Old Nov 7, 2008 | 12:56 PM
rmv42158's Avatar
Thanks I know hwo to get the fan belt off, i shoudl have reworded it abotu the fan clutch. That is goign to be my biggest obsticle being i don't have the proper tools.
Old Nov 9, 2008 | 10:51 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
divide the number by 12 to get FT LBS and you don't have to remove the belt or the fan clutch to change the intake gasket. shouldn't even have to touch it.
Old Nov 10, 2008 | 10:03 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Also, Harbor Freight has torque wrenches with inch pounds - and I think Sears does, as well.
limited edition 1
Jan 27, 2023 11:07 AM
Melrock83
Jul 3, 2012 06:51 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
