intake manifold aftermath
Old Apr 21, 2008 | 09:53 AM
guywm25's Avatar
guywm25 is an unknown quantity at this point
Default intake manifold aftermath
Hi any comments or sugesstions would be appreciated, first off replaced the intake gasket, put everything back together, now the situation is this, I still need to replace the fuel pump, but after replacing the intake gasket, cleaned the grounds, flushed the cooling, my charging system will not go past 10 volts, checked the connections, seem good there, had the alternator bench tested good there also. battety is just a few months old any suggestions the the charging system not working properly after disconnecting everything just wondering if i may have missed something
Old Apr 21, 2008 | 12:15 PM
fun2b1's Avatar
fun2b1 is an unknown quantity at this point
Default RE: intake manifold aftermath
not sure but I had a similar issue in a cavalier i had.. I'd assume theres a fusible link between the alternator and the battery... if you can with the vehicle running test between the alternator terminal and ground.. if you have your voltage there and not at the battery I'd want to say the fusible link may be gone.. just an idea...
Old Apr 21, 2008 | 02:30 PM
95LS's Avatar
95LS is an unknown quantity at this point
or if its not a fuseiable link id test the battery it might have a bad cell.
PowerBlazer
Mar 4, 2013 05:29 PM
dunontme
Nov 17, 2009 11:04 PM
rpishoman
Headers, Intake, & Exhaust
Dec 3, 2005 01:58 AM
blazerdan
Jul 14, 2005 12:51 AM
00blazer
Mar 30, 2005 12:24 PM
