Interior light stays on
Old May 6, 2007 | 08:06 AM
skynyrd1's Avatar
skynyrd1 is an unknown quantity at this point
Default Interior light stays on
I cannot shut off the interior light in my 1997 Blazer... anybody hear of this before?
Old May 6, 2007 | 10:05 AM
hillbillyinOhio's Avatar
Default RE: Interior light stays on
My guess is you have a door pin jammed, or broken. Look in all door jambs, in front doors, they are on the sides of the dash.
Old May 8, 2007 | 01:24 PM
Hanr3's Avatar
Or you left the dimmer control switch in the overrid position, or you have a over ride switch on the rear doom light and flipped it on.
Old May 10, 2007 | 07:44 PM
rickcald's Avatar
rickcald is an unknown quantity at this point
My 99 blazer is doing the same thing, I think I found the problem, my back hatch is causing the issue, I will take the car to work and clean and check that area, will post my results.
Old May 11, 2007 | 09:05 PM
rickcald's Avatar
took blazer to my shop and opened the hatch, cleaned out debris, took a rubber mallet and tapped the rubber seal all around the opening, cleaned the hatch latch, sprayed a light lube on hinges and latch and other items that affect opening and closing, results of all this is positive, the light goes out properly now, sure hope this helps.
Doggpool
May 24, 2011 08:17 PM
CA
Dec 26, 2007 12:15 PM
cmmyers10
Dec 19, 2006 03:43 PM
blazerscooby
Feb 10, 2006 09:09 PM
