intermittent a/c
Old Aug 20, 2016 | 01:45 PM
kmartin's Avatar
kmartin is an unknown quantity at this point
Default intermittent a/c
I have a 2003 blazer 123981 miles. I have started noticing that the a/c starts blowing warm air, most notable when I slow down. Then after a while it will start making cold again. It happens when its the warmest. What could be causing that? Any good fixes?
Old Aug 22, 2016 | 07:20 AM
Tajohns34's Avatar
It sounds like your compressor isn't staying on. It could be the switch on the receiver dryer that turns the AC off if you are low on refrigerant, they are known to go bad. Also, you could be low on refrigerant and that could be why it is shutting off.
Old Aug 24, 2016 | 05:14 PM
kmartin's Avatar
So basically, what i am hearing is that I am low of refrigerant. The switch on the receiver dryer is going bad? But yet it shuts off a/c when its low on refrigerant. Do you think I should get one of those refrigerant cans from the store?
Old Aug 26, 2016 | 09:50 AM
Tajohns34's Avatar
It is likely an either / or situation. If your AC turns on at all it most likely is not the switch. I strongly advise against using one of those refrigerant cans from the store. I would have a shop check your refrigerant level to make sure. If you use a can and overfill it you can cause serious damage. If it is low then you most likely have a leak that needs to be diagnosed or you are just wasting refrigerant.
45auto
Nov 19, 2006 10:11 PM
marks89
Nov 19, 2006 05:52 PM
greengoose89
May 16, 2006 05:06 PM
md95
Apr 14, 2006 01:49 PM
MontegoRX
Feb 15, 2006 11:30 PM
