Issue closing Sunroof properly
Am I missing something? Am I not all there? (never mind, everyone knows I'm not). I love to open the sunroof, but can't seem to close it correctly. If you push "close" too long, it pops up the back side an inch or two. I have troubles finding that sweet spot, where its completely closed. I usually get out and look from the outside while I push the button back and forth until it's closed correctly. Is there an easier way to close it, maybe even from inside?
It shouldn't tilt up unless you release it and press it again. They close should close flush as long as you hold it. Once you release and press close again is when it tilts. I've never had that issue with mine...
Also, when it's tilted it's the same thing. You can hold it until closed, and it shouldn't auto-open until you release and press again.
And a tip...please post your vehicle info in your sig or your post when you're posing a tech related question. I'm assuming you have a 2nd gen since you posted it in the 2nd gen board, but it makes troubleshooting hard when we don't know what you have for a vehicle.
Rotanilrac
Apr 12, 2021 09:37 AM
MetalMan390
Jan 19, 2015 08:24 PM
