Issue closing Sunroof properly
Old Mar 1, 2010 | 07:50 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Default Issue closing Sunroof properly
Am I missing something? Am I not all there? (never mind, everyone knows I'm not). I love to open the sunroof, but can't seem to close it correctly. If you push "close" too long, it pops up the back side an inch or two. I have troubles finding that sweet spot, where its completely closed. I usually get out and look from the outside while I push the button back and forth until it's closed correctly. Is there an easier way to close it, maybe even from inside?
Old Mar 1, 2010 | 07:56 PM
Sisk's Avatar
It shouldn't tilt up unless you release it and press it again. They close should close flush as long as you hold it. Once you release and press close again is when it tilts. I've never had that issue with mine...
Also, when it's tilted it's the same thing. You can hold it until closed, and it shouldn't auto-open until you release and press again.
And a tip...please post your vehicle info in your sig or your post when you're posing a tech related question. I'm assuming you have a 2nd gen since you posted it in the 2nd gen board, but it makes troubleshooting hard when we don't know what you have for a vehicle.
Old Mar 1, 2010 | 08:05 PM
jjnemoiii's Avatar
Sorry, I'll add that asap. 2001 Blazer 4x4 94,000 miles
Old Mar 1, 2010 | 08:06 PM
Sisk's Avatar
No worries..same as mine. Give my suggestion a try. It should work for you. If not, you may have an issue with your switch or motor.
Old Mar 1, 2010 | 08:18 PM
jjnemoiii's Avatar
Thats how I thought it should work, but many times it seemed to keep going. just tried it several times, worked just like you said. Thank You for the help.
Old Mar 1, 2010 | 08:44 PM
Sisk's Avatar
No problem. Glad to help.
Old Apr 13, 2016 | 08:07 PM
pmanwarren2015's Avatar
pmanwarren2015 is on a distinguished road
i just put a kit in mine and now my moon roof only goes half way any help would be great
Rotanilrac
Apr 12, 2021 09:37 AM
MetalMan390
Jan 19, 2015 08:24 PM
bkillgo
Mar 28, 2011 04:04 PM
wlorton
Mar 14, 2010 09:08 PM
