Just replaced alternator and it tried to die on me 02 Blazer LS 4dr 4x4
It's rebuilt but it has a lifetime warranty.
Huh? Isnt that new information.. I dont see where oyu mentioned that. What does your voltage gage say?
Well I suppose I did forget to mention that didn't I? The reason that I replaced my alternator was because I was running a 1000w stereo amp without the big 3 upgrade or a capacitor, which I removed as soon as I noticed these things. My headlights were really dim, and said instrument lights were flickering or pulsating. The voltage is reading at around 15/16 when first started but it goes down to a little above 14 when warmed up.
OK so I cleaned both the MAF and IAC Valve, and now the idle will not stay stead it jumps around, but it has not died yet. Also the speedometer needle is pegged at 100 and won't move. Is there a certain length of time that I need to run it for? Or a reset type thing? I am just confused ... Also I replaced the battery and that fixed my lighting problems.
Thread title "replaced alternator" plus the flickering , pulsing ect . led me to suspect You had installed a faulty rebuilt alternator. Not a big deal to return it for a replacement ... maybe get them to verify spec'd output before leaving the store with the new one
how do i know where factory put it ... damn it might be too low now. idle bad
YES Shift Timing! pettyfog is right! Check solonoids as well in the trans...
aerovette99
46
09-28-2015 10:04 AM
david068513
13
08-14-2012 09:47 AM
incbed
07-24-2009 02:15 PM
JVS
03-08-2005 09:00 PM
