Key turns too far
I've searched the forum for a similar issue to what I have and haven't found anything. The key turns and starts the car just fine. Most of the time when turning the car off it works fine. But lately when turning it off it goes past lock to ACC. I wouldn't notice it except when I pull the key out and the door is opened the chime rings like the key is still in. Do you think it's an issue with the ignition lock cylinder or possibly the ignition lock housing ? Maybe even the ignition switch itself ? I'm open to suggestions.....
Lock cylinder and key are worn your best bet is to remove cylinder and take to locksmith to have re keyed cheaper if you remove yourself. Mine is so worn I can remove while engine is running doesn’t really bother me enough to break down Colum yet you can by a cylinder from parts store but won’t match your doors
MetalMan390
01-21-2011 10:27 PM
mbrjay
09-03-2009 12:53 PM
Smoked
02-21-2009 03:20 PM
