lifter noise?
Old Dec 14, 2010 | 11:07 AM
Kainon's Avatar
Kainon is on a distinguished road
hope this helps,
I'm not sure about the newer 350's but on the older ones the valve lash adjustment is not a tighten till it's tight method. on the SBC and 4.3 V6 the lifter needs to be in the proper position on the cam shaft ( base of the lobe ).
There are several places on the net to find the information, you need to know if you are at the firing position for #1 or #6 when the TDC marker is at ZERO on the balancer/pulley
SBC Order
http://www.thedirtforum.com/chevyvalves.htm
brians1bad72
Feb 18, 2010 02:45 AM
mudnsno
Nov 15, 2009 05:38 PM
michigan_engineering
Jun 10, 2009 01:06 PM
chevyman30571
Feb 26, 2008 06:32 PM
glenmoore670
Feb 15, 2006 11:08 PM
