lifting my blazer help
i was told by a friend that if i tightin the bolts that are on the torson bars. the one that are where they mount . and told me if i jack up the front end and tightin them that it will lift the front of the truck. any imput would be great thanks
If you look around the forum you will see there is a "Lifting Tech" section. It will tell you everything you need to know. If you can't seem to find it here is the link. https://blazerforum.com/forum/lifting-tech-44/
ok well i just peaked under my truck and it appears that the driver side is screwed all the way out and the pass side seem like its 3 quaters of the way screwed in it seem like its a little lower on the driver side but not that much so my ? is why is it almost level what would cause it to be almost level but the screws are way differnt
