Looking for closest CLIFF
Old 03-10-2007, 12:54 AM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Default RE: Looking for closest CLIFF
If it's a fuel pump problem, then the problem is getting current to the pump, not the pump itself. Since it works when you aren't starting it from your battery, I'm still thinkin' electrical connections.
  #22
Old 03-10-2007, 09:27 AM
Hanr3's Avatar
I am undecided about Duralast parts at the moment. I just started using them, and so far haven't had any trouble.
  #23
Old 03-12-2007, 09:10 PM
Gonzo7's Avatar
Gonzo7 is an unknown quantity at this point
I'm takin it to a mechanic in a couple days, but I'm pretty sure that a fuel pump will be in line to be purchased. Does anyone have recomendations for brand or type? I know that I can get an OE style, in-tank pump at autozone for about $78, but if there's a performance type I can get I might consider it. Thanks again.
  #24
Old 03-13-2007, 06:09 PM
clone432's Avatar
clone432 is an unknown quantity at this point
OK, forgive me if this has been suggested....I started skimming posts.
have you ever had a battery fail....by fail leak acid at the post? I had this happen and I was left stranded for a couple hours until I decided to check the cables (about a month or two after the battery broke) and I was geting no power to the truck at all. Once I went to take the cable off I had corrotion just pooring out of the cable. I was able to clean it enough to get going but I have seen this a few times and it is the last place you would look.
95 Chevy Blazer
  #25
Old 03-13-2007, 06:31 PM
Very true! AC Delco batteries are known for acid leaks on the positive terminal. My Bravada did this and one day just didn't have any power. Jump started it, then proceeded to start it under its own power for 10 consecutive starts. After I let it sit for 10 minutes, absolutely no power again. Replace the battery and haven't had the problem again.
  #26
Old 03-14-2007, 01:33 AM
Hanr3's Avatar
^ Yep. AC Delcos about 4 years old. Teh positive post likes to corrode away inside tha battery. Every thing looks normal to the anked eye, until you remove the cables.
29pineavenue
03-04-2014 09:22 PM
dropwiser
25
03-05-2013 10:24 AM
JesterRob04
Shows & Clubs
04-24-2011 09:50 AM
DDOffroad
03-24-2010 06:35 PM
Hellfish
11-11-2009 09:28 PM
Quick Reply: Looking for closest CLIFF
