Loosing coolant and can't find leak!
Old Jul 31, 2008 | 01:07 AM
jimbaustert76's Avatar
jimbaustert76 is an unknown quantity at this point
Default Loosing coolant and can't find leak!
I have a 99 v6 blazer 4wd and I am loosing coolant. I can smell it but can't find the leak! I do have a puddle under my Blazer and it looks to be dripping down the left side of the engine/transmission. I warmed up the engine and even drove it but I still can't find the leak. All radiator hoses are dry to my knowledge and I replaced the water pump 2 years ago. Please help!
Old Jul 31, 2008 | 05:12 AM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
Default RE: Loosing coolant and can't find leak!
maybe it is coming from the engine block. you could have a bad gasket or something like that
Old Jul 31, 2008 | 06:33 AM
Default RE: Loosing coolant and cant find leak!
I will assume that the puddle is coolant and not just condensate from the A/C system (since you said it was on the left-driver side which is opposite the condensate drain). It is possible that the driver rear freeze plug is leaking or you have a faulty intake manifold gasket (more likely than a freeze plug).
Old Jul 31, 2008 | 08:10 AM
skoot61's Avatar
skoot61 is an unknown quantity at this point
I had a very similar coolant leak such as yours in a 97 6cyl Vortec. It was a head gasket leak. Dealer repair was $648.00 (parts and labor)
Old Jul 31, 2008 | 02:58 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
i had the same thing happen to me, it was an intake manifold gasket and it was around 600 parts and labor
Xaphoon
May 2, 2012 09:04 PM
mafiaboy01
Dec 2, 2011 07:30 PM
robbie.lawley
Oct 17, 2011 06:36 PM
goerzenl
Oct 29, 2010 07:51 PM
deathman
Oct 8, 2010 10:14 AM
