Low Beam problems.
Old Jan 4, 2012 | 10:03 AM
James1965's Avatar
James1965 is on a distinguished road
Default Low Beam problems.
Ok on my 98 blazer I have this issue now where when I start the car the low beams come on right away.. thus giving me quad daylight driving lights and at night I can turn the high beams on and off just fine except on high beam the low beams still are on.. they never shut off.. I have replaced the DRL relay and the other light relay in the fuse box under the hood. no difference at all. So now i'm wondering where to look and what is causing the low beamers to stay on full time.
Old Jan 4, 2012 | 06:47 PM
Esty's Avatar
Esty is on a distinguished road
A couple of questions
when you push in your e-brake dureing the day your drl should go off do your low beems shut off
and have you done anything that had to do with wireing raido lights alarm auto start ect.......
if the drl thing works you may want to read this post
https://blazerforum.com/forum/2nd-ge...g-light-66609/
To tell you the truth it sounds like something back feeding the low beem switch it could be a short in the switch its self
Old Jan 4, 2012 | 07:59 PM
TMM217's Avatar
TMM217 is on a distinguished road
Did u check the 15amp fuses in the under hood fuse box? I think there is one for left and right side a total of 2 fuses.
Old Jan 5, 2012 | 04:25 AM
James1965's Avatar
havent checked a fuse since the lights are on. not sure what the parkign brake has to do with lights but will check it shortly since i'm heading out to work in a few minutes. and I havent done anything with the electrical except a few months back i tapped into the low beam wire at the headlight bulb for a fog light tap. will see what happens today with the parking brake. Quad lights wouldnt bother me at all but I like having my fog lights on in this area. cant have them stay on with high beams though as it is illegal in Pennsylvania.
Old Jan 5, 2012 | 07:56 PM
Esty's Avatar
what happens when you remove the tap I guseing there is a relay in line with the fog lights try pulling that the relay may be going bad
Old Jan 6, 2012 | 04:21 AM
James1965's Avatar
well the drl go out when i hit the parking brake, but the low beams are stuck on... I have completely unhooked the fog lights from the system and no affect change. I just do not know what could make the low beams come on and stay on. like i posted earlier, I changed out the relays in the fuse box already and made no diff.. next step i'm going to try tomorrow is swapping out the DRL control box... I just dont know where to look now beyond that..
Old Jan 6, 2012 | 10:45 AM
TMM217's Avatar
Be sure to check the fuses cause I had a similar prob and I found the lfthdlght fuse blown a 15 amp
Old Jan 6, 2012 | 08:51 PM
Esty's Avatar
Im sry to ask this but is there something over your sencer for your auto lights like a pice of paper or something
Mike4x4ing
Jul 6, 2013 01:21 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
khalid_20879
Dec 28, 2005 08:47 PM
AzBlazer
Jul 3, 2005 04:17 PM
