Low Pressure Side A/C
Old 03-13-2007 | 04:51 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default Low Pressure Side A/C
This should be an easy on for somebody here - which one is the low pressure side? I think it's low on R124 and wanted to top it off. I have the one hose gauge that you put it in with. What's the max low side pressure it should be?
Old 03-13-2007 | 11:44 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Low Pressure Side A/C
On which vehicle? On your 99 it is R134a and you DO NOT want to put R12 in there.
Old 03-14-2007 | 09:43 AM
fnirish's Avatar
I didn't realize how little info a gave until you mentioned it. Sorry - it's the 99. And I meant to type 134a, somebody must have been talking to me (posted from work) when I sent it.
Old 03-14-2007 | 09:49 PM
Kordog's Avatar
The low side port is on the accumulator. It is located just outside the heater box, and the line off it goes into the compressor.
Old 03-18-2007 | 12:53 PM
ericd76's Avatar
ericd76 is an unknown quantity at this point
your low side port is the larger of the two ports. your pressure changes depending on air temp.,if the a.c. clutch is ingaged or disengaged.If you you have to add freon to the system than you have a leak somewhere in the system.If you want to top it off then you can but if you end up with more in the system than required total amount than you will actully lower your a.c. capabillitys
Old 03-18-2007 | 02:05 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
NO IT'S NOT! Low side is the smaller one! It's on the accumulator like Kordog said....jeees.
jdiaz
09-26-2023 11:29 PM
Streetracer94
10-29-2018 09:33 AM
LioNiNoiL
08-04-2011 02:47 AM
KenShriner
04-17-2011 07:44 PM
Wexinlo
04-06-2011 11:35 PM
Quick Reply: Low Pressure Side A/C
