Lubing sealed hub bearings
Old Dec 4, 2013 | 03:26 PM
metalmeltr's Avatar
metalmeltr is on a distinguished road
Default Lubing sealed hub bearings
we all know these bearings are prone to failure. I have found a group of people who have removed their abs sensors and injected grease into their bearing through the hole. This was on ford trucks. Has anyone tried this with a blazer? do you think the grease would effect the operation of the abs sensor.
Old Dec 17, 2013 | 02:32 AM
gatrucker99's Avatar
gatrucker99 is on a distinguished road
I am going to try this
Old Dec 17, 2013 | 04:05 PM
metalmeltr's Avatar
if you are willing to risk it please report your findings. I'm not sure if I'm more concerned about ABS interference or damaging the bearings.
Old Dec 17, 2013 | 04:39 PM
The grease will not affect the ABS sensor. I just wonder how effectively the bearing would be lubed, (not much room once you get the sensor out). Also, with expansion from the heat, the seal might leak from excess pressure. With the old style wheel bearings, if you packed them with too much grease, it would push grease past the seal when it got hot. Interesting idea though, might be worth a try.
Old Dec 17, 2013 | 04:50 PM
newguy's Avatar
Just dont go nuts with the grease, right?
Izzy207
Nov 24, 2010 08:43 AM
grime
May 13, 2010 10:58 PM
Alf
Mar 22, 2010 12:53 PM
abadinalbany
Jun 1, 2009 03:20 PM
bigdevo82
Dec 19, 2008 05:05 PM
