MAF Sensor compatibility
Old May 27, 2012 | 04:17 AM
Bish2113's Avatar
Bish2113 is on a distinguished road
Exclamation MAF Sensor compatibility
Hello again, recently my MAF sensor has gone bad and i'm looking to replace it with a junkyard one. However i'm not sure what makes the MAF sensor compatible so i'm coming to you guys for some automotive wisdom. I assume it needs to be from the same engine type(4.3l v6 w engine) but i may be wrong. Any help would be greatly appreciated.
98 Chevy Blazer LT 4dr 4x4 auto with 4.3L (L35?)
Old May 27, 2012 | 09:42 AM
burned's Avatar
burned is on a distinguished road
I am pretty sure they are all the same. Everyone I have seen looks the same, dimensions and electrical plug wise.
Did the filaments in your old one break, improperly cleaned it?
Old May 27, 2012 | 04:23 PM
Bish2113's Avatar
Default .
No I used CRC MAF sensor cleaner to clean it. I was getting P0101 codes before I did that though. The filaments have what looks like a burn mark on them. They still seem to be held in place by what I assume is magic.
Old May 27, 2012 | 04:40 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If you use the tube with the cleaner and spray it at those little filaments you can usually get everything off and for everything else use some que tips after spraying it all down with the cleaner. but dont touch the filament with the que tip. But i assume you already read the how to on cleaning it.
As far as what will work, any MAF from a 4.3 '96+ should work. i would only look in Astro's, s-10's, and Blazers (or similar's) just to be on the safe side.
chevy lady
Aug 29, 2007 10:17 AM
N1ZZN
May 14, 2006 12:08 PM
khalid_20879
Mar 27, 2006 11:16 AM
MikeForS
Mar 25, 2006 04:43 PM
ivannj
Feb 11, 2006 03:00 PM
