making noises
Old Mar 28, 2006 | 09:28 PM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
Default making noises
ok i kinda asked b4 and nobody was able to give an answer so i thought i would try again and see what ppl could come up with. thanks anyone that can give me any help at all even opinions. ok so now to the problems when im take off from a standstill at about 2,500 rpm it makes a weird noise when the rpm is still climbing its kinda like a spraying rubbing noise hard t oexplain but thats the best i can do sry and it makes this noise in any of the four gears and not only at this rpm its just usually around there(this noise happens everytime i drive my truck)....second part of the question is sometimes but not as often as the first question my truck makes another noise....when i take off it will make a rubbing noise like its dragging a 45 lb weight behind my truck on concrete (haha sry thats the best way to descibe it) and its always after i stop and mostly once i have just shifted from reverse for some reason...its always fully in the gear to when it makes the noise or atleast it shows that it is...again any help would be great im leaving for out of town tomarrow at 12:30 so i wont respond after that i need help please mechanics are expensive....by the way i do have a loose or bad alt. belt becasue it squeeks like no other when its cold out but besides that the alt. when it kicks in seems to be unusually loud...Bearings maybe?
Old Mar 28, 2006 | 09:35 PM
kaindragoon36's Avatar
kaindragoon36 is an unknown quantity at this point
Default RE: making noises
I've heard that noise before, and it was my A/C Compressor for the first one. As for the Weight on concrete noise, I'd check out your differential. also, if your drums in the back are out of adjustment, they could rub. Go in reverse, and step on the brake rather hard to automatically adjust them. Do it a few times.
But who knows, I could just be crazy
Old Mar 29, 2006 | 01:51 AM
2001blazer's Avatar
good idea about the a/c compressor but would it still make that noise if i turned it off
bigdaddykane93
19
Jan 8, 2014 05:41 AM
ComputerNerdBD
45
May 20, 2012 10:36 AM
xxdatricandudexx
May 24, 2009 09:31 PM
BLK85
Jun 7, 2007 01:37 PM
BobTheBlazer
Feb 18, 2007 04:41 AM
