Measuring current draw on battery
Old Nov 24, 2007 | 12:14 PM
rlb's Avatar
rlb
rlb is an unknown quantity at this point
Default Measuring current draw on battery
I'm trying to chase down a dead battery problem on a 97 Jimmy. I used a multimeter to test the battery draw, and I'mgetting 25ma draw which drops to 5.5ma when the radio fuse is pulled. Is this enough to drain a battery over night? Is this a typical amount of draw for the radio circuit? Its a factory radio BTW.
Also, will opening the door wake the BCM? I had the door open (necessary for fuse access...)with the courtesy lamp fuse pulled. The ignition had been off for more than 20 mins before testing (and I didn't turn it on at all during testing).
Old Nov 24, 2007 | 12:15 PM
rlb's Avatar
rlb
Default RE: Measuring current draw on battery
BTW I found some good info here that I based my testing on
https://blazerforum.com/m_89775/tm.htm
Old Nov 24, 2007 | 06:33 PM
Chevy Lover's Avatar
I believe that opening the door will wake the BCM. Try removing the door jam switch and then waiting 20 minutes before re-testing.
Rule of thumb for battery parasitic load is ....check the battery reserve capacity and divide by 4. For example if the battery reserve is 90 minutes, then 90/4=22.5 so parasitic load should not exceed 22.5 milli amps.
carbongixxer
Oct 9, 2013 01:13 PM
yarinzim
Feb 24, 2013 12:09 AM
Barbara
Jan 22, 2012 09:53 AM
djdrew010
Oct 29, 2008 08:20 PM
rwrows
36
Jul 25, 2008 12:13 PM
