mechanic stumped
Old Nov 23, 2018 | 10:17 PM
scooby's Avatar
scooby is on a distinguished road
Default mechanic stumped
I went out to start my Blazer (2000 4.3 4WD 140,000 miles) and it didn't start. Had to have it towed to the shop. The mechanic put in a new passlock module and still the same problem. Engine turns over but will not start, only sometimes. When it does run the Security light flashes. He figured out 2 things: #1 if he turns the key very slowly it will start, if you turn the key at a normal speed it won't start. #2 If the Blazer is out in the cold (there's snow on the ground) it won't start but if it is in the shop and warmed up it will start. So he ordered a new key cylinder and still have the same problem. All of the electrical tests on the computer check out OK but it acts like it's an electrical problem. Compression is good. Etc. It has a new fuel filter and the fuel pump was replaced a couple years ago. The battery has full charge and checks out OK while cranking. All fuses are OK. The mechanic has had my vehicle for 1-1/2 weeks and is baffled. Help - I want my Blazer back.
p.s. - I don't want to bypass the security.
Old Nov 23, 2018 | 10:34 PM
You did not mention if the fuel pressure was checked. I would guess it was from what you wrote.
I have heard of the ignition switch going back in these. When you mentioned changing out the ignition lock cylinder, was that separate from the switch?
Old Nov 24, 2018 | 06:34 AM
scooby's Avatar
Default Not sure what you mean
They rekeyed the lock so I guess that would be the switch. Thanks
Old Nov 24, 2018 | 03:33 PM
I'm not so certain that re-keying an ignition switch changes out the electrical part where the problem could be.
I found this on RockAuto listed as the ignition switch:
https://www.rockauto.com/en/moreinfo...361461&jsn=488
Which is different from the lock cylinder which is listed separately.
https://www.rockauto.com/en/moreinfo...361461&jsn=518
Old Nov 24, 2018 | 03:37 PM
By the way, I do have experience with an ignition switch going out; just not on my Blazer. It was on my 82 Honda Prelude. It happened while driving. The engine just quit on me. Fortunately it happened in a small town that was surrounded by many miles of open wheat fields. I had no cell coverage so I was able to use the phone of a local shop to call a friend. Turned out the electrical part had worn out with no warning. I found a replacement but the lock cylinder was integral with it although I was able to have it re-keyed.
For the Blazer, the lock cylinder and the switch seem to be not-integrated.
Old Nov 24, 2018 | 05:26 PM
scooby's Avatar
I did not see the part he called a cylinder. I will check on Monday. I'll keep you posted. Thank you
Old Nov 30, 2018 | 02:41 AM
GeorgeLG's Avatar
Have you checked to see if you have spark during a crank but no start condition? If not then trace backwards
spark at plug
spark into distr
signal into coil
signal and power at icm
George
Old Nov 30, 2018 | 07:52 AM
scooby's Avatar
Default Problem Solved
Replaced the lock cylinder and ignition switch and now starts w/o problem. Thank you Christine_208, next time I'll have the mechanic call you.
Old Dec 2, 2018 | 01:14 AM
You are very welcome. I like it when people can benefit from the lessons I learned "the hard way!" LOL
Old Dec 2, 2018 | 01:18 AM
Oh and Thank You for reporting back what worked! It is the follow-up posts that can be the most helpful for those who in the future have similar problems. I know I've been one who has benefited.
eknox327
25
Dec 13, 2018 11:33 PM
RatrodRacing
Jan 17, 2012 10:36 PM
steve1969
Jun 15, 2011 10:41 AM
Fozzy
Mar 6, 2010 05:14 PM
lunari
Jan 4, 2009 07:50 PM
