Metal Skid Plate mod for 4-button transfer case??
Old Apr 21, 2019 | 07:26 PM
Default Metal Skid Plate mod for 4-button transfer case??
Hi all,
So I purchased from eshaw (thank you sir!) a set of the front suspension, engine, and transfer case metal skid plates to install on my Blazer. When I got them I knew there could be an issue with the one for the transfer case. It is designed for the smaller 3-button t-case but I have the larger 4-button type the a skid-plate for which has a deeper pocket to clear the t-case.
Has anyone modified one of these earlier metal t-case skid-plates so that it could be used with a later 4-button t-case? If yes, what did you do?
Old Apr 22, 2019 | 07:24 AM
eshaw's Avatar
I've seen them dropped down with the use of aluminum spacers. It requires longer bolts too. I think that would be your easiest recourse.
Old Apr 25, 2019 | 08:03 PM
N. Jensen's Avatar
I think I ran across a thread on here from years ago where a member used a very large hammer to bend it closer to shape.
Or, keep an eye out for a metal 95-98 ZR2 trans case skid. I just saw one earlier today at my local pick n pull. That'll bolt up just fine.
Thuwaldt
19
Apr 17, 2019 01:34 PM
95teal4x4
May 1, 2017 03:43 PM
DSMayo
Jun 4, 2010 10:04 AM
99blaz
Mar 29, 2010 09:31 PM
jimmyboy
Jan 24, 2007 01:27 PM
