Minor overhaul to 95 "w" Blazer.
Old May 4, 2014 | 08:09 PM
Gmas95's Avatar
Gmas95 is on a distinguished road
Default Minor overhaul to 95 "w" Blazer.
Getting ready to pull the engine due to freeze plugs leaking. Going to repair what is needed. So far I plan on doing the following.
-Freeze Plugs
-Spider Injection unit, 1 year on new one and 3 year on the reman torn on which to buy.
-Thermostat
-Water pump
-Oil lines to oil filter
-Valve cover gaskets
-Upper intake manifold gasket
- EGR valve
- Full basic tune up- plugs,cap,wires etc.
All parts will be OEM, Delphi/Delco
Any other areas I should address?
Old May 6, 2014 | 08:40 PM
Gmas95's Avatar
This is a picture of the freeze plug, this is why I am pulling the engine. The two in front are leaking and both sides by the engine mounts are leaking. I figure the two in the bell housing are also failing.
Attached Thumbnails Minor overhaul to 95 "w" Blazer.-leaking-freeze-plug-.jpg
Old May 7, 2014 | 02:22 PM
spittybays
Guest
Posts: n/a
Almost positive you can do that without yanking the motor. Not sure but I would do some research. I know people have fixed them with just JB weld. There just casting plugs for were they made the block.
Stop now and read!
Old May 8, 2014 | 03:59 PM
Gmas95's Avatar
I am pulling the motor, Removed the torque converter cover and was able to view the 2 freeze plugs behind the flexplate. 1 is leaking 1 is fine. The truck only has 91k on it and has been garage kept since the day it was bought, so for a 1995 it is in wonderful shape and I intend on keeping it that way so I wont be doing anything but the correct repairs on the truck.
I was just wondering if I should pull the timing cover and lower intake manifolds while I have it out, I guess logic says yes because it is the best time to do it, but nothing is leaking.
Also what about the lifters? they were fine when I parked the truck so I imagine there is no need to remove/inspect/replace them.
It is not my daiily driver so the downtime is not an issue. I plan on treating any rust areas in and around the engine compartment while the engine is out also.
I also need to pull the tranny dipstick to media blast the inside as it has corrosion, any easy way to do this with the trans in the truck? there is a support bar around it that is part of the tranny bellhousing bolt I am assuming that has to be removed? Or can i wiggle my way around it?
Old May 8, 2014 | 11:28 PM
spittybays
Guest
Posts: n/a
how many miles? And what motor there were a couple that year.
If your intent on pulling why not do everything you have access to.
I would do an oil pressure sending switch, that's one thing on mine I would have toved to have the motor out
Yea and you don't have motor mounts on your list, I did not see them at least.
charlietuna
18
Dec 22, 2010 11:39 PM
benniekong
Sep 28, 2010 07:46 PM
mdjuarez93
Feb 1, 2010 10:03 PM
ChevyguySS68
May 30, 2009 03:45 PM
joerum
Engine & Internal
Mar 30, 2009 03:56 PM
