MityVac vacuum brake flushing?
Old May 28, 2011 | 07:55 PM
marklar's Avatar
marklar is an unknown quantity at this point
Default MityVac vacuum brake flushing?
Anybody else out there have any luck using a MityVac to flush out the brake fluid? Ye olde two-person method will take forever, and does not seem to work... Since I've got access to the MityVac, should the vacuum flush method it work? And should there be any problems with the ABS?
Old May 28, 2011 | 09:27 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Easiest way I've found with ABS brakes is gravity bleeding. Crack open the right rear and keep the reservoir full. When the fluid comes out clean, close it then do the same to the left rear. Then to the right front, then finally the left front.
It'll take a while, but don't wander far - you don't want the reservoir to go dry.
toms2000blazer
Jul 26, 2012 11:59 PM
litterbug
Mar 21, 2011 01:44 PM
soundguy
Sep 13, 2007 03:25 PM
Blazin 4x4
Sep 21, 2005 01:26 PM
Blazin 4x4
May 25, 2005 01:57 AM
