Most Common Issues with 2002 Blazer?
Old Feb 25, 2023 | 08:06 AM
Jmack's Avatar
Jmack is on a distinguished road
I have a 98 Blazer (I don’t know if this would be the same for other years). How do I keep my fuel tank clean?
Old Feb 25, 2023 | 09:04 AM
LannyL81's Avatar
Have had my '02 LS for over 15 yrs now, have had to replace the fuel pump, door hinge pins, everything else that I have replaced were for preventive, not failure. I have replaced all of the steering components over the years with the exception of the steering link as it is not available. Also replaced upper control arm, lower ball joints, spark plugs, distributor, plug wires, rotor caps, brakes, calipers, replaced U joints, half shafts, front bearings, shocks, and am on my third radiator. Mine had an oil leak, found the front two oil pan bolts missing, but that was not the oil leak source. The main oil leak was the oil filter adapter for the remote oil filter. The oil lines on mine were not leaking at all, but I replaced them anyways. I found the leak to be between the oil pan and block where a good amount of RTV is used. I replaced that but apparently, I did not use enough RTV in the front cover to oil pan joint, so I get to do it again.
The BEST thing about the Blazer is it is super reliable! Does not matter what the temperature is outside, turn the ignition key and engine catches within a second...every time!
Get it....you will not be disappointed.
Old Feb 25, 2023 | 09:24 AM
Jmack's Avatar
Thanks but I don’t know if you answered my question, unless you’re saying I should replace my fuel pump to keep my gas tank clean.
Old Feb 25, 2023 | 05:14 PM
LannyL81's Avatar
Sorry Jmack....I did not see that they original posting was several years old.
As far as keeping your fuel tank clean.??...do not understand what that really means.
Old Aug 2, 2023 | 09:16 AM
Jmack's Avatar
Do you know if the LIM gaskets failing applies to 1998 Blazers? Do you know approximately how many the miles the trucks could have when they fail?
Old Aug 2, 2023 | 10:52 AM
I don't recall the exact year range but I'd say that 1998 is definitely included. As soon as I heard about the LIM gasket failures, I replaced them on my 99.
As for age, I don't know but 10 to 15 years is not uncommon to hear ofhearm failing.
The issue with the LIMs is that they leak into the liftet valley with no obvious indication that they are failing. Worse, they can fail all at once with no warning and ruin your engine in a few moments as the coolant mixes with the oil and is pumped through the engine.
two hints for doing the repair: temporarily install studs in the LIM bolt holes to help guide the LIM into place and use good RTV on the front and back walls to the lifter valley.
Keystone40
Apr 8, 2018 12:30 AM
blazedblazeroffroad
Mar 18, 2018 01:04 AM
spliteye
Feb 26, 2018 08:50 PM
caropractors
Jan 22, 2018 09:38 PM
Hank
Mar 28, 2012 02:54 PM
