name this liquid?
I agree here. You could've got water in your differential. That's what and oil water mix looks like. You could've then go a leak in it, so it's showing up in your driveway. Check the front and rear differential for droplets of the same looking stuff. You can also take out the fill plugs and see if it comes pouring out, or stick your finger in there and get a sample and see if it's the same creamy/milky/carmely color. You can check the mountaineer if yours checks out.
is there a pic on where the fill plugs are? sucks about being a visual learner lol
what color normally is the differential oil?
New, good gear oil should be kind of a brown/amber-ish color, about like motor oil. It doesn't really get get dirty dark brown/black like motor oil. Unless there is water contamination, or some other contaminant got in there, it should look about new.
Here is a pic I found of oil contaminated with water.
On the rear diff, the plug (i think) is on the passenger. It will have a recessed square where you can insert a ratchet or breaker bar. I think it will be 1/2, maybe 3/8 breaker. There is no drain plug. To drain it, you have to take the cover off, unless someone at some point replaced it with an aftermarket cover with a drain and fill plug. I'm not positive on the front. I think it's on the drivers side maybe just in front of the cv axle shaft. If you search around the forum, you can probably find some pictures.
in the meantime til the show melts ill park 10 feet away from where the spot is now and see if it instantly comes back or if its just oil
I would doubt that you would have a leak that bad and it not be visually noticeable outside of the diff itself (around the cover and gasket). It doesn't hurt to check though. Usually for you to get water and oil to mix together that well, you need some kind on mechanical assistance... ie: gears in a diff. It usually won't mix like that on the ground. Especially since there is black oil on the ground next to it, it doesn't seem likely to me that the rain did that to oil that was already on the ground. Oil and water go together like oil and water.
while im waiting for weather to improve, which seems to take forever lol. i may as well learn, how does water actually get inside differentials? is there a vent or something ? figured i could also check if there is the mix in there what i could look for hopefully nothing too serious but things never seem to be a quick fix
there are vents. The front one has a tube that runs up through the engine bay and attaches to the fan shroud next to the upper radiator hose. You should see it there with a plastic cap looking thing. If you don't see it, it's missing or hanging down. I could also be damaged. All of these issues could allow water in the diff.
jdcapri
09-20-2011 05:56 AM
