need help missfire
Old Jun 2, 2014 | 04:33 PM
Tenthjester65's Avatar
Tenthjester65 is on a distinguished road
Default need help missfire
Okay 2001 blazerr 2wd I havee the random multiple missfiree code done plugs cleaned map and throttle, body new ignition coil. New cap and rotor jist got truck 2 months ago. Planed repairs wires pcv i dont think i have a tone of trnny fluid and if I do i think ots dirty and ready for service and air cleaner airfliter. Thos multiple missfire is caused loss of powerr hesition increasing. Fule consumption ever time I fill up.i was told the camshaft position sensor is most likely my problem . And will correct all those problem is this truue what are ur thoughts on thos please help.
Old Jun 2, 2014 | 08:47 PM
Tune up parts are not the place to cut corners to save money. AC Delco plugs #41-993. Cap & rotor need to be AC Delco. Wires need to be good quality, not a cheezy store brand.
Check fuel pressure and leakdown & post the results.
If the camshaft position sensor did not set a DTC, it's fine. Camshaft position sensor will not affect engine performance, save your money. It may need adjustment though. Have a knowledgeable technician check/adjust camshaft retard using a scan tool capable of accessing cam sensor streaming data.
cizxtreme
Aug 30, 2013 04:00 PM
BLK85
Jul 1, 2008 07:52 PM
OH_VDUB
Apr 27, 2008 09:13 AM
crey 95 Blazre
Jan 6, 2008 07:41 PM
thefox1
Apr 9, 2005 07:30 PM
