starting rough
Old Jun 1, 2014 | 09:25 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default starting rough
this has been an ongoing thing since ive owned the truck 5 years. i am on my third starter, i assume the first one was oem. the second was a dud so i dont even count that, and the current one was a reman prostart from pepgirls. the battery is a year old, alt is 2. and no corrosion on my terminals.
any who, when i go to start it, especially after sitting for a day. it doesnt not start, but it wasnt as smooth as it used to be when i first put it in. idk how to explain it besides sometimes when i turn the key it starts either a little rough or perfectly.
what could be causing it? im dumbfounded, note it always starts and no noticeable volt drop when driving
Old Jun 1, 2014 | 11:07 PM
odat's Avatar
Is what you are trying to say starter sounds different off and on [draging sometimes] - if so check starter mounting bolts for looseness - bushings could be worn - check wireing at starter corrosion or looseness - selonoid could be getting weak - brush could be hanging up slightly in starter - just a few things to start you off with....
Old Jun 2, 2014 | 01:58 PM
er0ck273's Avatar
yea my last starter cracked in half, but yeah thats the word i was looking for "dragging" especially when i do the remote start. might just drop it if the bolts are tight and check what you recommended, what size bolts are they?
Old Jun 2, 2014 | 02:15 PM
odat's Avatar
if mem serves me right bolt heads are either 14mm or 9/16 - older starters used a 3/8 dia bolt - reman starter it could be anything - if you change out the starter again and if you have a Oriellys there most of their starters, alts and such have a life time warrenty on them - yep you have to save the reciept in most cases but it's a one time buy if you do
Old Jun 2, 2014 | 05:34 PM
er0ck273's Avatar
this prostart from pepgrils has a lifetime warranty on it, but hows that work.. over the years the value depriciates?
Old Jun 2, 2014 | 09:08 PM
odat's Avatar
with the starter you have i can't say as I don't have a pep here - with Oriellys if it's bad you take it in and trade for a new one straight across
RandyRhoadsFan82
Mar 29, 2014 11:22 AM
blazerguy22
Nov 14, 2013 11:50 PM
nhguy261
Dec 30, 2010 01:41 PM
c10jm
Aug 12, 2008 05:34 PM
greenclover19
Mar 26, 2008 03:13 PM
