Need Help with Vac line found not connected
Old 10-23-2013, 06:51 PM
The image in post #6 is taken from the center of the engine looking at the left inner fender. The part on the right is the ABS unit, and the part on the left is the cruise control module. It's possible that the plastic nipple is broken off flush with the vacuum reservoir, in which case, you won't feel it.
This image show the orientation of the reservoir, (the arrow points to the front of the vehicle):
Here is another view, (the arrow points to the front of the vehicle):
Attached Thumbnails Need Help with Vac line found not connected-reservoiramplines_zps1a7c4744.gif   Need Help with Vac line found not connected-vcuumreservoir_zps80128f64.png
Old 10-23-2013, 07:12 PM
HostileJava's Avatar
HostileJava is on a distinguished road
Thanks, I'll try again tomorrow.
Old 10-24-2013, 11:18 AM
blackedoutv6's Avatar
blackedoutv6 is on a distinguished road
So on non 4wd Blazers, is one of the ports on the side of the check valve that has 2 nipples (lol) just capped off? Or does it go to something else?
Old 10-24-2013, 04:50 PM
On 4WD there is an additional vacuum Tee with a line that runs down to the vacuum switch on the transfer case.
Old 02-02-2024, 09:27 AM
C210M's Avatar
C210M is on a distinguished road
Would the nipple be located in the same location on my 2004 blazer?
Old 02-02-2024, 09:53 AM
LesMyer's Avatar
LesMyer will become famous soon enough
AFAIK, Yes
Old 02-02-2024, 11:43 AM
C210M's Avatar
I found the vacuum res but the nipple is broke off. How do I fix that?
Old 02-02-2024, 02:29 PM
christine_208 will become famous soon enoughchristine_208 will become famous soon enough
The nipple on the vacuum reservoirs is recessed. Have you confirmed this?
If the nipple is broken, I suppose you could epoxy in a plastic tube or try to replace the reservoir. I've attached the instructions for replacing the reservoir but it requires removing part of the braking system (also attached).
The part number for the reservoir looks to be 15720833
(https://www.gmpartsgiant.com/parts/g...tra2=&filter=())
The final solution is to find a vacuum reservoir that can be mounted somewhere else. The 1st gen Blazers had one that was attached to the inside of a fender or to the underside of the hood I think.
https://www.dormanproducts.com/p-17836-47076.aspx
BigEffingHammer
03-11-2013 07:46 PM
ccross13126
01-20-2012 10:07 AM
gpeebles
05-05-2011 10:08 AM
speedfreak81
02-04-2010 08:52 AM
va454ss
02-17-2008 08:45 AM
Quick Reply: Need Help with Vac line found not connected
