New blazer owner need help
Old Aug 3, 2011 | 06:41 PM
coltan.holmes's Avatar
coltan.holmes is on a distinguished road
Default New blazer owner need help
Ok so i have a couple issues..
First my a/c.. when i am running the a/c on normal 1,2,3 levels it works fine. however when i want to blast it the ac just stops working. i think it might be a resistor and would like a 2nd opinion.
Second my power levels... My truck accelerates fine from the 0-30mph range.. but when i am on the highway and want to merge or pass or just go fast for no reason i have alot of draw from the engine but it just barely creeps along from about 30-50 mph range. Im thinkin it might be a clogged fuel filter or fuel pump.
please help
Old Aug 3, 2011 | 06:50 PM
Lets start with some vehicle information.
If 1, 2, & 3 work, then the problem is likely with the high speed relay.
Are there any stored trouble codes?
Old Aug 3, 2011 | 07:06 PM
thats a negative on any codes
Old Aug 3, 2011 | 09:31 PM
oh and i have a rattle that sounds like metal on metal comin from the cat.. any suggestions
Old Aug 3, 2011 | 09:55 PM
zr2dan's Avatar
zr2dan is on a distinguished road
what year is your blazer
Old Aug 4, 2011 | 06:25 AM
berniescout's Avatar
berniescout is an unknown quantity at this point
pluged cat. is rattle inside? or is it a heat shield? if inside, I would replace cat.
bernie
Old Aug 5, 2011 | 05:36 PM
its a 96. Its the heat shield i just put some strapping on it seeing as how im gonna replace the exhaust here shortly. I just changed the fuel filter and it was GNARLY couldnt see the white paint in the parkin lot through the black funk that came out of it. It was def. a 150k mile fuel filter. The power levels picked up alot but it still hesitates like its gotta think about goin up in RPM's
LS99Blazer
Dec 2, 2013 06:34 PM
brandywine050
Sep 9, 2011 02:53 PM
Skwid339
Jul 21, 2011 09:28 PM
Ryanols1on
May 10, 2011 05:16 PM
