new blazer owner questions
Old Sep 24, 2013 | 08:34 AM
dpmeeks's Avatar
dpmeeks is on a distinguished road
Default new blazer owner questions
I just picked up a 98 Blazer 4.3L 4x4 2dr. It has 189k miles and basically I know nothing about the maint. history. It seems to run and drive fine. The only issue the PO said he replaced the heater core and due to residue you can still smell antifreeze thru the vents. I don't think he fixed it..
Anyways.. other than the possible heater core job, what other issues should I look for on this blazer, I guess known problems. thanks for any help !
Old Sep 24, 2013 | 11:27 AM
burned's Avatar
burned is on a distinguished road
I will list two things that are important to check. Lower intake gasket, and oil cooler lines.
There was a post on this site recently with the same question, please search for it. Too many things to list again.
Old Sep 24, 2013 | 11:29 AM
burned's Avatar
Old Sep 24, 2013 | 11:34 AM
chris015's Avatar
oil lines,lower manifold gasket,fuel pump(must be ac delco,nothing else period).
/thread
Old Sep 24, 2013 | 07:20 PM
jimspahr@msn.com's Avatar
I would watch the coolant level very closely. If you are losing coolant, get a coolant pressure test done to see if you can pinpoint the leak. I would make sure the heater core drain hose is clear and not clogged or kinked in any way. The smell of coolant could be many things including a loose hose clamp, a cracked hose, or a bad heater core. But always check for the little things first. Be sure you are checking the passenger foot area under the dash for wetness. That's usually where a bad heater core leaks.
For all the other common problems, read this forum and you will see some patterns developing. Fuel pumps, Spiders , intake man. leaks, electrical problems, are just a beginning. Welcome to the club.
Old Sep 24, 2013 | 08:31 PM
dpmeeks's Avatar
thanks for all the info.. I did find out the heater core was not changed so im guessing with 189k it needs it. I did find out the PO replaced the intake gaskets and new fuel pump assy. so I guess that's a good thing. Im hearing what sounds like a hub bearing just cant pin point which side...
Old Sep 24, 2013 | 09:06 PM
Not too many problems with the valve stem caps on the tires... never heard of any complaints on them... but that's about it On the bright side.... parts are easy to find and cheap to buy. Bookmark Blazer Forum on your computer for diagnosis & repair procedures and you'll be fine
Old Sep 25, 2013 | 01:34 AM
richphotos's Avatar
/thread
You are drunk, dont forget about Delphi.. dummy! :P
Tinted
Dec 8, 2010 07:03 AM
bill737
Aug 26, 2010 07:13 PM
grimace007
Jul 16, 2010 09:21 PM
Actioneffect
Feb 16, 2010 02:22 PM
bezerker
Nov 9, 2009 04:00 PM
