new Guy needs HELP
Old Nov 12, 2013 | 02:58 PM
GaBear's Avatar
GaBear is on a distinguished road
Going to try a new O2 sensor this weekend and will look into the ground wire also. The gas guage needle will bounce around when I first start up going from Full to Half and then somewhere in between for about a minute then will stop. I will also see about getting a fuel pressure test done in the next couple oof weeks unless the truck starts acting up.
Old Nov 14, 2013 | 07:34 AM
GaBear's Avatar
Update::: Took truck by a muffler shop. they tested the system and said that the Cat is deffinately bad. They tested the O2 sensors and said they are working properly. Was Told it would cost $700 to replace cat and exhaust system from cat back. I think I can find a cheaper price. Will do some checking tomorrow. If I knew how to weld I'd do it myself.
Old Nov 14, 2013 | 08:08 AM
chris015's Avatar
EASTERN CATALYTIC Part # 50363
$263.79 from rock auto.
from the looks of it you cant buy "just" the cats. you have to buy the whole y pipe back. If i were you id buy the setup,but cut the flanges off the new system that connect it to the manifolds and have them welded onto your existing pipe. 99% of my life of removing manifold bolts at least 1 breaks,and is a pita to remove.
Old Nov 16, 2013 | 08:20 AM
GaBear's Avatar
Chris
I have done some checking with some of the local parts stores. I have found a universal cat to put on. All I have to do is cut the cat off and reweld the new one back in place. Looks Like I'll have to do the same thing for a muffler. I measured my Cat and muffler and found universals for both. Now to find a shope that will install them for me fairly cheap.
Old Nov 29, 2013 | 09:03 PM
GaBear's Avatar
Ok guys I need some info. What size is the inlet and outlet of the catalytic converter pipes? I found a Good deal on a universal Catalytic Converter But I need to make sure I'm getting the right size.
chevyblood64
Apr 5, 2011 08:42 PM
Attnhor
Feb 2, 2011 03:50 AM
trukin55
Apr 16, 2010 05:37 PM
kymatt
Feb 11, 2010 09:57 AM
redeye202
Nov 18, 2009 03:34 PM
